Results 1 to 18 of 18
  1. All,
    I am trying to download a flash file that is being viewed in a non-standard player. Are there any pieces of software out there that would let me grab the "source"? I have tried Moyea, Replay, Realplayer (only got the audio), the Firefox add-ons, etc. with no luck.
    Here is the page: http://www.pictage.com/photographer/slideshows/viewslideshow?slideshowid=4169&slidesho...qnhtgewelnjmzz
    In the end, I would like this slideshow as an mpg. I tried using SnagIt but the quality was terrible.
    Thanks for your help!
    I would try streamtransport (free) or if that wont work another screen capture tool like replay video capture.
  3. Neither of those worked. StreamTransport could not find the video URL, and Replay only produced a blank file
    Any other suggestions?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Download Helper grabbed the music...
  5. Originally Posted by hech54 View Post
    RealPlayer did too ... now all I need are the images
    Even if I can't get them both with the same tool, I can always splice them together ...
  6. The images and audio are automatically downloaded in your temp internet directory of your browser cache, you can find them there
  7. There is a file that is about 12MB ... but I nothing I have tried will open it
  8. Member leghorn's Avatar
    Apr 2007
    Germany
    You could try this:
    - delete all temporary files in IE
    - run VideoCacheView (http://www.nirsoft.net/utils/video_cache_view.html)
    - load the page in IE
    Maybe you can get the video file that way. VCV should work flawlessly with IE, don't know if it does with other browsers too.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    give up. it's an encrypted swf.
    <embed base="http://www.pictage.com/photographer/static/static/slideshows/swf/." src="http://www.pictage.com/photographer/static/static/slideshows/swf/SlideShow3.swf" quality="high" bgcolor="#000000"
    width="630" height="420" name="SlideShow3" align="middle"
    play="true"
    loop="false"
    quality="high"
    allowScriptAccess="always"
    type="application/x-shockwave-flash"
    pluginspage="http://www.adobe.com/go/getflashplayer"
    flashvars="basehost=http://www.pictage.com&imagewidth=630&imageheight=420&sli deshowid=4169&slideshowkey=ujqnhtgewelnjmzz&autopl ay=0">
  10. VideoCacheView only found the music too ...
    So there's really no hope? Are there any video recording apps that would give me better resolution than SnagIt?
    Thanks everyone for your help.
  11. this isn't a video; this is a slideshow, the .swf and accessory files allow for the show and transitions
    the actual assets, the individual .jpg photos and music are stored in your temp internet directory, you can make your own slideshow with a program or editor
    if you want to record the screen , use something like camtasia. You can even record uncompressed or lossless compression (Huge filesizes), and then re-encode to mpeg2 or whatever format you wish later
  12. That makes sense. Thanks!
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the actual pictures aren't sent to the temp folder. all you get is a xml list of the load order. this is part of it.
    load=/home/image/proxydb/L/B/LB105/2009/729415/01/01_D_S_0001.jpg|prop=below&amp;wdth=630&amp;hite=6 30&amp;cb=0|flush</url></image><image><ordernumber>30</ordernumber><scannum>4</scannum><url>http://c15.cache.pictage.com/servlet/PIS?awmarkg=/home/image/anssets/watermarks/LB105/LB1052009.jpg|load=/home/image/proxydb/L/B/LB105/2009/729415/01/04_D_S_0004.jpg|prop=below&amp;wdth=630&amp;hite=6 30&amp;cb=2|flush</url></image><image><ordernumber>31</ordernumber><scannum>6</scannum><url>http://c15.cache.pictage.com/servlet/PIS?cwmarkj=/home/image/agssets/watermarks/LB105/LB1052009.jpg|load=/home/image/proxydb/L/B/LB105/2009/729415/01/06_D_S_0006.jpg|prop=below&amp;wdth=630&amp;hite=6 30&amp;cb=0|flush</url></image></images></data></response>
  14. I just tried Camtasia, and I got video but not audio
    Man, this is turning out to be a lot harder than I expected!
  15. Originally Posted by aedipuss View Post
    the .jpg's are saved in IE, perhaps you are using another browser?
  16. Originally Posted by istock1 View Post
    I got audio in camtasia, it has to be toggled on, and make sure your global audio settings are on as well. Personally I wouldn't use the audio from camtaisa, because if you record it as lossless , you will have a generation loss when you re-encode it (unless you plan on leaving it as wav). It would be better just to mux in the original audio
    Well you have jpg, and audio, you can make it yourself easily in slideshow software, or any editor. You could even use the recorded "video" and overlay the audio
  17. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    firefox 3.6.3. interesting about ie, which version are you using?
  18. Originally Posted by aedipuss View Post
    the actual pictures aren't sent to the temp folder. All you get is a xml list of the load order. This is part of it.
    the .jpg's are saved in ie, perhaps you are using another browser?
    firefox 3.6.3. Interesting about ie, which version are you using?
    ie7
